SOURCE: I have a Haier 18
No, i don't believe u are. these small fridge will run longer during the day as they have limited cooling capacity and the heat load is higher during the day. there could also be a problem with the cooling system and if there is one, the problem will become more noticeable and it will stop cooling. otherwise, i would leave it as is
SOURCE: My Haier 12 wine bottle cooler is dead. No fan or cooling .
Check the 2 fuses,one covered with black heat shrink, next see if internal fan is spinning, inside door, the 2 fans on the back should spin when first plugged in. also the 2 led's red and green should light up...if internal fan doesn't spin then check or replace, use batteries to get it to spin as a test...good luck,safety first...
SOURCE: My Haier built in wine cooler's beeper is
Kindly provide few more details :-
1. Is there any cooling issues that you might have observed?
2. Is the compressor running?
3. Any error message or blink sequence or anything you might have observed?
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Koldfront makes a great dual zone cooler. I found you one that holds 18 bottles with
space for 6 bottles of white wine and 12 bottles of red.
