RCA 39" class LCD HDTV 39LB45RQ - ON Corp US, Inc Logo
G
Graciano Gaminde Posted on Dec 12, 2013
RCA 39LB45RQ not turning on
Not turning on
RCA lcd 39lb45rq turns on but there is no picture or sound
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Rca tv troubleshooting
Check to see if it has accidentally been put on a sleep timer
Had tv on for a few hours and it turned off not to come back on
possibly fuse(open) or capacitors(bulging at top) in power supply, but could also be Power supply PCB or Main PCB
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
