Antes de gastar en partes nuevas, debes desarmar el aparato y inspeccionar. Le llega la corriente al motor? Funcionan los switches de limite (que detienen al motor en su punto), algun engrane, o fusible quemado?
Are you sure its the condenser fan? The fan is attached to the compressor power and wont run unless the compressor is running. On the other hand the fans inside the cooler will run 24/7 and are designed for continuous duty. If someone has worked on the compressor wiring you may have to re establish the wiring following the wiring diagram. I have seen condenser fans wired in hot areas to run continuously to attempt to cool down a hot compressor or compensate for a worn out or damaged condenser that doesn't get rid of the heat from the system. If that is the case a new condensing unit is probably in your future. Hope this helps good luck.
Unfortunatly, your repairman is correct. The evaporator section (part that makes things cold) of this case is build into the wall and if it is leaking it is not repairable.
