No 310 but is 301? incorrect memory
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
SOURCE: Konica Minolta Bizhub 920
the copier recognised the paper,but when printing/copying the feeder doesn't pull the paper and on the machine it says paper misfead,open front cover.
SOURCE: there is an error code
Abnormally high toner density detected Black TRC sensor-
1. Correct the TRC Connection on the underside of the imaging unit if faulty
2. Reinstall black image unit
3. Change image unit
4. Change PWB-M
5. Change PWB-MFP
you can try # 2 then run 20-30 sky shops (copies with lid up to make black copies) put a white piece of paper over lead edge section of copy glass so you are only making 1/2 black copies if you don't the copy may jam in the fuser due to excess toner. after running copies turn machine off for 10 secs to reset and power backon. if problem continues I would change the image unit.
SOURCE: konica minolta Bizhub C6500 error code 2424
Hi, I have a C6500 Bizhub pro, but, recently displays an C2404 error. I need to print an urgent job and y can't!
Please helpme!
