You really need a volt / ohm meter to check for Continuity & Volts Its well worth the investment... $15.00 bucks give or take a few I would check to see if you have 220v to back of dryer where the cord mounts to dryer, If dryer is getting only 1 leg 110 volts instead of the 220 will it not heat. Check themostates & heater for Continuity... Most models, Now have a.. Hi-limit fuses that need to be checked for Continuity
If your dryer isn't getting hot it and drying clothes it sounds like the heating element is out. I is a easy fix.
Inglis IED4400SQ0 - I thought it was my heating elemnent I tested continuity using a multimeter on all of the 5 pieces ( fuses and heating element) turned out it was the thermal cut fuse. I very temporarily shorted it to confirm, and that's what it was. Gonna go buy the new kit tomorrow thanks for all the help.
Inglis dryer will not stay running,then not restart
I have the same problem, and I'm fixing it myself, or attempting to fix it. I'm trying to change the coils (2) (1 has 3 prongs, one has only 2) there are little knob pieces molded to them, are they supposed to be face up or down? can't remember, maybe a diagram would be GREAT! Its an Iglis gas dryer
More info - it's an Inglis dryer it this helps the troubleshooting process....
I am having the same problem. dryer does not heat and cycle will not shut off, have removed the back panel to gain access to thermostat and element. I have a new volt meter but i am unsure of how to use it or what setting it should be on ,,
Dryer is actually fairly new (less then 3yrs) , have checked for lint blockage(none) & discharge hose is also clear,
any solutions or assistance on how to use the volt meter would truly be appreciated,,,
INGLIS DRYER MODEL #X087500.
WHERE IS THE SWITCH BOX LOCATED SO THAT I MAY CHANGE THE FUSES?
THANK YOU
My dryer runs but wont get hot and does not dry clothes. It also runs on the cool air setting but does not stop. It is only 3 years old!!!!
Someone help!
Dryer tumbles and blows air, but doesn't heat. Checked and cleaned then vent...checked the fuse box to make sure it had not been tripped. Still does not work. Inglis dryer.
I clean the lint every time. I took the bottom panel and there was so much lint, I cleaned this all out. why did this happen?
inglis gas dryer
