Hi Virgil , I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?Hi Virgil , I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
You can't post conmments that contain an email address.
It is not your pump, because despenser and ice maker both get water from the same pump.
Water despenser is activated by a small plunger when you press your water glass against it
to release the water. This is your problem, bad plunger.
found that when I used the crushed ice option, the lines would freeze up. Cubes were ok. Take everything out, including the ice, and turn it off for about 12
hours. Then check to see if it works again. If not, wait a little longer to let it fully defrost. If it still does not work after 24 hours, then you might need service.
under the trim there are 2 openings on on each side insert a flat head screw driver and twist so it will unlock and then it will be off hopefully you dont have to remove all insternal parts inside dispencer i will try one tomorrow at work and let you know
yes replace the board and at the same time you need to order the replacement bulb for the light in the despenser socket a regular bulb will bolw the board
I would try putting on the light at the dispenser. It worked for me but took almost 24 hours to work. I am now keeping the light on all the time. Simple solution to try. My ice was working when the water was not coming out.
