I have a VX37L HDTV10A unit. I turned it on today and the image jumped around then turned black. When turned on the Vizio logo turns white, the screen is black, back light is on, sound and controls work. The first time it happned i gave the TV a little slap on the back and it fixed itself. Turned it off and on and having the same issue. When a source is not plugged in the screen flashes blue but picture is not aligned.
SOURCE: Vizio VX37L HDTV10A no picture
Hi.
You need change the Main board. You have a micropros. problem.
SOURCE: Have a Vizio VX37L that when it is turned the
HERE'S THE FIX: I just went through this with my Vizio VX37L. TV is stuck in RGB input. This is the fix....
(option 1) Power on TV, and press the INPUT button repeatedly and rapidly until you can change to a different input, such as AV.
If that doesn't work, try:
(option 2) With the TV off, press and hold the INPUT button on the side of the TV for about 5 seconds. The TV should power on and the input list will appear. The TV will no longer be locked, and the INPUT button should function properly after that.
Option 2 worked for me!
SOURCE: Missing colors on vizio vx37l hdtv10a. Powers up and has picture but looks like its missing reds
check for a loose connection at the t-con board fixed the lvds cable.
