You replace the drum and developer. Pior to that you clear counters and run the require procedures after because if you reset your drum unit without replacing it the codes will begin to show up the copier works on the counters when you clear it then the copier thinks the drum is new an set voltages as required since it is not new then you get problems . Replace the drum, cleaning blade and developer and do it right!!!!!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Konica Minolta Magicolor 2400W drum cartrige-how to replace?
Did you buy a whole new drum unit, or just change the cartridge? If so, the fuse may still be blown. Also, you may need to empty the spent toner out of the old cartridge.
SOURCE: Reset Chip on Konica Minolta 8031 Imaging Unit
I can provide you with a programmer to reset the chip. They are only about $500-$700. Still interested?
SOURCE: need to reset admin code for konica minolta c-350
Hello
press utility/counter - then under the counter "details" - stop 0 0 stop 01 -
now you are in service mode, - stop 0 C, and there shold be admin pwd
SOURCE: how to replace drum unit for a konica-minolta
Press left side top cover release.Open top cover,open cartridge >open drum unite.
SOURCE: Can I reset the drum counter for a Konica Minolta
The best way to reset the counter is to replace the fuse on the underside of the printer drum. That is not hard to do, but you have to be careful not to break the plastic tabs holding the original fuse in place.
