Bought several months ago at michaels and have never attempted to change nozzle till today. After thoroughly heating the unit, the tip and base will not separate and only turn together as one piece.
Here is a great blog on how to change a glue gun nozzle. But big things to remember, preheat the gun, use gloves or a wrench and be careful! If you don't preheat your glue gun, you are likely to strip the nozzle and then be unable to use it again and may even break the gun. Hope this helps!
http://www.gluegun.com/blogs/tips-tutorials/7918501-how-to-change-a-glue-gun-nozzle
SOURCE: I am having difficulty glueing PVC together. I
3M Hot Melt 3764 is the correct adhesive for PVC.
SOURCE: glue stick is stuck in glue gun and can't be
Make sure you plug in the gun so glue is soft if gun not getting hot the you have another problem
SOURCE: linoleum has curled up beside bathtub
There probably is a reason that it curled and I would guess it is because of moisture getting behind the linoleum. If the linoluem wasn't sealed properly where it meets the tub, that could be the reason. I would use a good grade of construction adhesive (Lowe's, Home Depot....) BUT clean and dry the area you are going to bond to VERY carefully. Remove any old debris or glue. BE CAREFUL if you use a heat gun. It will melt cheap linoleum in a second. Try a hair dryer first and be patient....Once you have it glued (followig the mfg. instructions on the tube), lay something(s) HEAVY on the linoleum and let dry overnight. THEN run a bead of grout and tile sealant along the edge. Good Luck.
SOURCE: I have a glue gun
i actually did this to one of my workshop guns i found the best way to fix it was to heat the gun up using a hair dryer and then pushing the old glue back up the tube and out and now when im not using the guns i take the glue stick completely out
best of luck
merry christmas
SOURCE: Cold heat glue gun directions??
Hi There,
Just flip the switch either forward for a brighter light or towards the back for a dimmer light wait 2 mintes and you're ready to go Unless of course its like mine & just want to be a dim flashlight not a glue gun.
A hot glue gun is a very useful tool for joining modelling
materials and even more substantial materials can be fixed together with it.
'Sticks' of solid glue are pushed into the back of the gun, the trigger is
pressed pushing the glue stick forward and molten glue comes out of the nozzle.
The glue is manufactured from thermoplastics.
On the front bottom there's a stand that you need to left up over the nozzle base for stability.This will keep it from turning.Hope this help in best crafting.
