SOURCE: Zanussi
The drain filter is clogged (E20)
online manual
http://www.serviceforce.co.uk/pdfs/U21039.pdf
E21 Problems with water drain in wash phase
Check the drain hose and pipe for blockages.Replace the component if necessary.Good luck with the machine.Please do post comments and results.
SOURCE: Electrolux EWX14540W washer dryer error code E72
have power but does not rotate I NEED SERVICE ASAP
SOURCE: how to disable the alarm on a Zanussi ZWD16270W1 washing machine
To deactivate the audio alarm that denotes the end of the cycle signal carry out the following procedure:
press the left two buttons in the row of three buttons on the front panel for six seconds, carry out the procedure again to reactivate the audio alarm.
(The two buttons are labelled as SPIN and OPTIONS respectively)
SOURCE: my zanussi washer dryer wjs 1397 w drum is not turning
It is most likely that the drive belt is broken and needs repalcing, If you remove the rear panel it will be obvious if it has broken *** there will be a lrge flywheel attached to the drum and no drive belt going to the motor, near the bottom of the machine. These are easy to obtain from any domestic appliance spares store or mail order. They are also very easy to fit.If the drive belt is in place and is reasonably tight (taught) then you may have an issue with the motor. clutch or brake.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
