My machine has hardly been used( has been stored away for a few years well wrapped) thought I would try to get the hang of it again but the hand wheel will not move I have oiled it but no joy so far
SOURCE: Janome 134D Overlocker
Set you differential at 1.0 and your loopers at about 3-4 the needle thread tensions are usually around 5 to 6.
I would also suggest that you place four different color threads on machine to make it easier to adjust all. Now if you are using only 3 threads the same applies.
Also------patience.
SOURCE: janome mylock 634D overlocker
this very same thing happened to my flat machine turned out to be a piec of material jammed in the workings also wrong oil used or it might be thread jammed try and see
SOURCE: My Janome 10000 has been sitting idle for about 6
Remove the top cover (3 screws) and lubricate with good quality thin lubricant the top shaft running horizontally through the machine. This haft has 2 bushes and is a common source of seizing, especially at the handwheel end.
If this doesn't cure the problem have it serviced by a technician (there are numerous lube points inside the machine and these should be adressed every 12 - 24 months.
SOURCE: free owners maual for janome overlocker modle 134d
You may be able to get a free manual from Janome - http://janome.com/index.cfm/ContactUs/General_Inquiries
