Will not install on w8
SOURCE: Sony DSC-P72 close up photos
When in Macro mode, the focus on your camera is locked at 3.9 inches (10 cm). It will not autofocus in Macro mode. So your ring should be 3.9 inches from the lens. It is important that you have enough light. Your one flash shot shows that the flash is too bright for macro work. So bring in a small table lamp to illuminate the hand and ring. A goose neck lamp would be nice. In macro mode, the depth of field is quite narrow and a well lit subject helps increase the depth of field. The depth of field is the portion that will be in-focus. It might help to have a dark background. Place the hand on a black cloth or black paper.
SOURCE: photo capacity
i'm pretty sure there's a button you can press which gives you options to change the sizes of your photos e.g. 2M, 3M, 6M
they make the file smaller and gives you more space to have a lot of photos
press around to see :)
hope this helped
SOURCE: MY CAMERA WORKS FINE ITS LIKE BRAN NEW HOWEVER ITS
hi,
this is the manual
http://www.digitalcamera-hq.com/digital-cameras/sony-cybershot-dscp72_question.html?qid=4266
memory card will cost 30-50$
thank you for using fixya,rate my answer
vijay
SOURCE: how to disassemble
Take a cloth pour some poroxide on it (not WET but damp) and run it over the circuts while its not powered up or has batteries
SOURCE: Hi, My sony cybershot dsc p72
Hello
OK, the max memory support on this camera is 4GB.
Kind regards
Andrea
Testimonial: "very grateful for the prompt response"
