Kenmore 43142 Front Load Washer Logo
Posted on May 06, 2009
Front load washer won't drain
I have a Kenmore front load washer that won't drain.
  • 1 more comment
  • marygro May 06, 2009
    Any ideas on how to fix it? It is a stackable unit with the dryer on top.
  • Anonymous May 09, 2009
    sears he2 front load does not drain complete. I do not see any water in tub, but can hear it when spinning it manually. Clothes aren't very dry after spin. I tried cycle to drain and no improvement
  • kosmoz13 May 23, 2009
    Kenmore front loading washer doesn't drain or aggitate just buzzes.
Dogwood
Level 1:
Guru:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Contributor 9 Answers
  • Posted on Mar 14, 2015
Dogwood
Contributor
Level 1:
Guru:
Mentor:
Answers
9
Questions
0
Helped
2525
Points
65
Well this answer is 6 years after the fact for this question, but for those of you who may see this question going forward from this point - here is what I found in my cloths washer. The fix was simple. Getting to it ... not so much. Hope you find this helpful.
www.youtube.com/watch?v=5Av5sb695XA
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 06, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
223
Points
Your water pump has something in it which keeps your pump from turning to push out the water.
2answers
Kenmore 90 series washer won't drain and go to spin cycle
Take the power plug off the wall. Be prepared for a lot of water before attempting the following. It doesn't spin because the unit is not draining water. It will not spin with water in it - must drain first. Check drain hose for kink,check exit pipe for blockage. Remove the front access panel, bottom front, screws beneath; if you find a pipe there with a cap -this is for draining water. Could be your "coin trap assembly" is blocked, therefore not allowing all the water to pump out. Remove the clamp (or unscrew) that connects the trap assembly to the pump and clean it out.
If helped pl say so.
Kenmore front load 110.46462501 mid cycle all lights flash won't drain
Check your drain pump/filter may be located bottom right of machine/hold drain hose over bucket with around 2 feet from floor level should pump if no blockage....Remove any blockage .hope this also solves tray fault
I have a Kenmore Elite washer, model 44092. The machine won't spin and the error code is E20. What is wrong with it?
The machine, based on the error code, is made by Frigidaire for Kenmore. Error code E20 pertains to a slow or no drain problem which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code.
Error Code E20 on Frigidaire and Frigidaire-made (including Kenmore) Front Load Washing Machines
Washer will wash but won't spin or drain
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
My washer won't spin and drain. what should I do?
heatman101
My washer did fill, but won't spin or drain now and the door won't open
Hi tragz,
If it can't drain, it won't spin. There may be something preventing the pump from draining in the Pump filter. You will need to clean it.
Please follow my below Tip on how to do it:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
Kind Regards d")
* If this solution helped you, please rate it
My Kenmore washer 20432990 will fill and agitate but won't drain or spin. When I push down on the lid switch I hear nothing but when I let it go I hear a faint click.
heatman101
2helpful
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
2answers
Water wont drain
something is stuck in the drain pump axcess through front panel.
Alexander
vince
