HP Officejet 5610 All-In-One InkJet Printer Logo
N
Nurali Mohamedali Posted on Nov 19, 2013
Oxd0620230 error 9put
How do i fix the problem of oxd0620230 ?
Abhay
Level 1:
New Friend:
  • Contributor 33 Answers
  • Posted on Nov 24, 2013
Abhay
Contributor
Level 1:
New Friend:
Answers
33
Questions
27
Helped
2142
Points
41
Hi, change printer's head carriage assembly.
2answers
000110-0001
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
How to fix error 651 on windows 7
Error 651 is a well-known bug in Windows 7 which happen when you try to connect to the Internet using PPPoE connection. If you're one of the victims who met this bug, you should see the following error message: Error 651: The Modem (or other connecting device) has reported an error. These connections, however, would work just fine in Windows XP or Windows Vista PCs. Below are a few solutions that can perhaps fix the problem:
Windows 7 Fix: Error 651 Modem PPPoE Broadband Internet Connection
Fix 1: - Error 651 Modem PPPoE Broadband Internet Connection
Click here to download Registry Easy to automatically fix your PC errors and speed up your system.
Fix 2: - Error 651 Modem PPPoE Broadband Internet Connection
The root of the problem is believed to be caused by the RAS PPPoE file raspppoe.sys found in the folder C:\Windows\System32\Drivers. To fix this problem, we will have to replace the file raspppoe.sys with a new one. Try to copy the file from your friend's computer which has Windows 7 installed. Alternatively, you can download the raspppoe.sys file from this site (thanks to the author). After you get the file, before pasting it into C:\Windows\System32\Drivers, be sure that you rename the original file to something like raspppoe_ori.sys, so that if something weird happen you have a backup of your original file. Paste the new raspppoe.sys into the directory after you've renamed the original file. Try to connect your modem and it should work fine now.
Hp deskjet 5610 error oxd0620230 reset power
take the power out hold # and 9
put power back and push the power button.
this is a hard reset.
Also check if the head is moving freely. use a bit of oil.
3helpful
4answers
HP5610 all in one, error message oxd0620230, reset power. I reset power, but it will not print, starts printing then I get the same message again.
This happens to me when my kids try to print something and it gets stuck in the print log and I can't delete it...I am not a cpu guru by any means, but I found these steps easy to do and it works....
1. control panel>admin tools>services> right click on Print spooler in list> press stop (leave this window open).
2. go to Cdrive>windows>system32>spool>printers>select all>delete
3. go back to print spooler in list from #1 and right click start
4. restart computer
There is almost always a "flash" off the page that the kids tried to print that "hangs" up the printer. I hope this helps.
5helpful
2answers
Error message Oxd0620230, hp 5610 all-in-one, i have tried all the power resets. the cartridge stalls when the code comes up but it don't always stall in the same position. lights flash... also have the...
error message Oxd0620230, hp 5610 all-in-one, i have tried all the power resets. the cartridge stalls when the code comes up but it don't always stall in the same position. lights flash...
2helpful
2answers
Oxd0620230 reset power
Below is the document that i want you to follow exactly in order to resolve you issue.
CLICK HERE ==>> DOCUMENT
Please let me know the outcome after following the steps.
thank you so much.
adonscott
k24674
Grand Canyon Tech
Grand Canyon Tech
