SOURCE: Konica Minolta BizHub C451 printing red lines down documents
your imaging unit is damaged. call minolta guys to have a look it at and change it if neccessary
SOURCE: error code when copying... C6103 on Bizhub C451
C6103 - Scanner overrun failure
The Scanner Home Sensor detects the Scanner at its home position during a period of time that begins with the time when a prescan command
and a scan preparation command are executed and ends when a home return command is executed.
SOURCE: c 2101 on bizhub c451
this error code means there is charge cleaner malfunction. during the backword movement if the cleaner the home sensor was not actuated after a predetermined amount of time. to reset the error code leave the machine on and open then close the front door if the charge cleaner motor has been disabled in service mode this error code will happen at start up
SOURCE: how do you reset the konica minolta bizhub c451
Network settings are accessed through the Administrator menu. Press Utility/Counter, then choice #3 should be Administator Settings. Enter your admin password and Network Settings should be choice #5.
Also, if the bizhub is already on the network, you can enter the IP address into your web browser and log in as an administrator to get to the network settings.
SOURCE: Our C451 Bizhub squeeks while idling...the techs
Have the techs replace the fusing unit, and install the update exit guide assembly (A0P0R73711)
This is a on going issue with this model, due to using induction heating, the fusing unit turns constantly, causing the squeak.
