Cutter Tools Logo
S
Sal Jones Posted on Nov 14, 2013
Can I use a portable bandsaw to cut rebar or do I need something stronger?
Candy Swan
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 20, 2019
Candy Swan
Contributor
Level 1:
Answers
Questions
0
Helped
1158
Points
A portable band saw will do just fine. When cutting rebar, remember to use safety equipment and tools like globes, safety glasses, and even boots. Rebar is quite heavy and you'll want to protect your hands while lifting, transporting, and cutting it. Put on safety glasses to protect your eyes when cutting rebar because it tends to create sparks as you cut it.
Make sure that when you're cutting rebar, you're doing it at a spacious location to where you're nowhere near flammable objects. Rebar tends to be sold in long rods and for that, you'll really need a big space where you can cut it. When you've measured and marked the rebar, you can proceed to cutting it. Aside from a portable band saw, you can also use a reciprocating saw. When cutting rebar, you might want to step on the rod or bar because it has the tendency to roll around during the cutting process.
You can add rebar safety caps to your list of safety tools and equipment when working with rebar. Straight2Site offers a variety of rebar safety caps, tying systems, and other construction equipment that you'll definitely need for your building projects.
zevy kol
Level 1:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
New Friend:
  • Contributor 24 Answers
  • Posted on Nov 14, 2013
zevy kol
Contributor
Level 1:
Mentor:
New Friend:
Answers
24
Questions
21
Helped
13986
Points
90
You can use a portable bandsaw to cut rebar, I find it to be the best solution when I can't take the rebar somewhere to cut it. But be careful if the metal is heavy it could fall and dent/damage the floor if you're working indoors of cause injury should it land on you.
Why is it important to scan concrete before you cut or drill?
If you drill into concrete without going through the scanning process, you won't know for sure if something will be hit. For instance, if you hit post-tension cables or rebars, you can create a significant compromise on structural stability. You also risk cutting into water lines or electrical conduits, which could cause power outages or, worse, electrocution and explosion. This can cost you time, money, and injury to workers.
Concrete scanning involves the use of ground penetrating radar (GPR) to survey the location of voids, conduits, rebars, post-tension cables, and anything else within the concrete that is invisible to the open eye. It helps you make informed decisions before doing any extensive project that could harm your property or any workers present onsite.
How do you lock femi 782xl Bandsaw for vertical operation
BandSaw at Trick-Tools
vansantent.trick-tools.com/tools/BandSaw
BandSaw found in: Femi NG160ABS Benchtop Semi-Auto Mitering Bandsaw, Ellis 1600 Dual Mitering Head ... ...that has a locking valve for setting up cuts. ... The HEM Saw 782XL portable bandsaw is a great fit for hobbyists and those needing an accurate portable ... JET HVBS-56M, 5 x 6 inch Horizontal/Vertical Bandsaw.
Band Saws, Horizontal & Vertical - Trick Tools
www.trick-tools.com > Sawing
Find Band saws in a variety of configurations including horizontal, vertical, ... Bandsawblades are a long lasting and low cost consumable, reducing the maintenance andoperating cost of this type of ... Femi 782XL Benchtop Mitering Bandsaw.
FEMI 782XL Swivel Head Portable Bandsaw 110 volt
www.stakesys.co.uk > Shop By Category > Metal Cutting Band Saw
The 782XL can be locked in a vertical position and, when used in conjunction with the optional table kit and quadrant, used as a vertical bandsaw for cutting ...
' The Saw That Cuts Straight
www.hemsaw.com/
Dec 16, 2015 • Saws
Blade drift with Milwaukee bandsaw
Worn band saw guides maybe? Or too much tension or change the blade , I use bi metal Haltbar band saw blades of sawblade.com
What protective gear should I wear when cutting rebar?
Wear protective gloves because rebar tends to get really hot when you're cutting it, you should also be wearing clothing that you don't mind ruining and isn't too flamable because sparks will come flying off the rebar when you cut it. Make sure to wear eye and face protection as well as sturdy shoes. This is not a job for the flip-flops!
Can i cut rebar with a hacksaw?
you can, but its not great for the teeth of the saw and it can get tiring. if you have any powersaws with metal cutting blades, that works best. if not, you can use the hacksaw but i hope you don't have too much rebar to cut
What is the best tool for cutting rebar?
i use a sawzall, but you can use almost any saw as long as you put on a metal cutting or diamond blade
Greenlee 531 bandsaw manual
Does anyone know the part number of the greenlee 531 portable band saw table
Jan 09, 2012 • Saws
1helpful
Want to know where to get owners manual
You can go to Milwakeetool.com and down load the manual for your tool.
Top Cutter Tools Experts
ADMIN Andrew
ADMIN Andrew
Kolbrun...
Are you a Cutter Tool Expert? Answer questions, earn points and help others
