I have problem with my ti 89 calculator i can u it in solvig matris pls if u can give the steps on how to go about it.
I assume you are speaking of solving a system of equations with a number of unknowns. If not, please correct me. Here's an example in practice:
If you have a system of 3 equations with 3 unknowns, you would set up your matrix so that the coefficients of each variable for a particular equation are on one row. So, given equations x + y + z = 0, 2x + 3y - 4z = 1, x + -z = -1 you would type the following into your calculator: [[1,1,1,0][2,3,-4,1][1,0,-1,-1]] and press enter to make sure you typed it correctly. notice that in the third row there is a zero, since we have zero time y for the third equation. Then row-reduce the matrix (2nd > 5 > 4 > 4 or in the CATALOG as rref). You should get out the matrix [[1,0,0,-1][0,1,0,1][0,0,1,0]]. This says that x=-1 y = 1 z=0 since my first column contained the coefficients for the x variable, the second for the y variable, and the third for the z variable. The last column contains the solution, the part on the other side of the equals sign.
Hope this helps! For more reading (from someone else; I just made this one up), check out the Wikipedia articles on Gaussian elimination and Systems of linear equations
You can create matrices as follows
[Apps][6: data/ matrix editor] --> [3:new]
In next screen where it says Data--> Use right arrow and select 2: Matrix. Create directory or leave it in main. in Variable: name the matrix
Enter row dimension. (m)
Enter column dimension. (n)
Press Enter and you will have the entry screen. Enter the coefficients and [2nd][QUIT]. You matrix has bee created.Commands available for matices are accessible by [2nd][MATH][4:Matrix].
For simple operations use +, -, *, raise to a power. If a mtrix has positive coefficients you can extract its square root.
Hope it helps.
The Ti 89 solves a lot of fraction problems by being in the right mode and, the use of several commands. One of my first problems here at Fixya was to find a solution for, "How do i convert a decimal answer to fractions prefferably with matrixes."
Here the problem was solved just by being in the EXACT mode.
Another fraction nightmare, so I thought was to solve for, "I want to solve a Binomial Theorem problem!" You have to go to the end of the problem but, I solved it just by the use of the expand command.
The best way to display fraction is in Pretty Print and, in the EXACT mode. Here is a small demonstration of the 3 mode setting in the Ti 89 and, the effect of each to the way a fraction is displayed.
This is a demonstration of the Ti 89 simplifying and, displaying in fractional form in the AUTO mode.
This is a demonstration of the Ti 89 making numbers proper and, displaying them in fractional form while in the EXACT mode.
This demonstration of the Ti 89 not even converting in fractional form and, displaying in the APPROX mode.
You should always use parentheses when entering equations or, fractions into the calculator. Pictured just below you can see how the Ti 89 can miss-interpret what is being entered.
The propFrac command is a great tool to reducing to the simplest form.
propFrac(expression,var). This will return an expression as a
proper expression
Sometime with joining or, combining fractions you have to get the common denominator. As you can see below the comDenom command is a great tool for that.
The Ti 89's ability to compute fractions is only limited to the ability and, knowledge of the person using it. Even though, it has a tendency of making a not so, mathematically inclined person look like they have been doing them all there life.
I just gave several ways I go about solving and, displaying fractions. The best way to display fraction is in Pretty Print and, in the EXACT mode. Sometimes that isn't even enough and, you have to use parentheses and, commands to do the job.
