Konica Minolta bizhub 161f All-In-One Laser Printer Logo
A
Anonymous Posted on Nov 12, 2013
Error 2703 en bizhub 600 - Konica Minolta bizhub 161f All-In-One Laser Printer
Ubaid abid
Level 2:
Guru:
  • Expert 164 Answers
  • Posted on Apr 17, 2019
Ubaid abid
Expert
Level 2:
Guru:
Answers
164
Questions
0
Helped
122893
Points
609
If the problem persists initialize the Fax board (Service Mode =>Fax =>Initialization
1 Related Answer
xeerie
Zaheer Ahmed
  • 347 Answers
  • Posted on Jun 19, 2010
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
Error code C-2703 Bizhub 500
bersihkan rumah korona bawah, dan ganti kawatnya
Rror 2703
Subject:
C-2702 and/or C-2703 code.
Description:
Solution:
PROBABLE CAUSES:
1. Failed T/S corona.
Remove the T/S corona unit. If blank copies can be printed without a service code appearing, replace the T/S corona unit (p/n 57AA R715 00).
2. The HV unit has failed.
Replace the HV unit (p/n 56AA 8401 2).
Por que impressora konica minolta bizhub c6000 apresenta error 2703
Check the Cyan Charge Corona housing. Remove it and reseat it. IF not that check the HV board. and or connection at the back of the drum and transfer middle assy.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Bizhub 600 machine reste en prechofage
reste en prechofage what is that
250 error codes
no such code
Error 2703 en konica minolta bizhub 750
Directly below the drum is the transfer and separation ration unit. which houses two very, very thin gold plated wires the one on the right is the transfer wire which transfers the image off the drum on to the paper as the paper goes over the wire while the drum place the image on the paper. the second wire is separation wire which has an AC signal on it to prevent the paper from sticking to the drum. The second wire might be broken. Have it replaced best to have booth done at the same time since unit comes out? or the spring at rear of the unit are not making good electrical contacts. Ensure power is off. as they do carry High Voltage during the normal operation.
Bizhub 600 has an error c-2703 what is the reset
Sir/Mam,
Directly below the drum section is assemble called the transfer/separation assy. (Pull out the middle section will see assy with black grids across it under the grids are some very fine wires) the purpose of this unit is twofold. (It houses several very thin gold plated wires) One wire is what helps the transfer of the image from the drum to the paper. Since the paper goes between this wire and the drum, the second wire prevents the paper from sticking to the drum during the transfer process. The code you have been getting means either wires might be broken, or has to be cleaned (because of all the toner on it from the drum assy. which needs to be removed and cleaned. Or The end blocks that hold the wires are getting old and allowing the High Voltage that is applied to the wire during the copy/print process to leak to ground. have a qualified tech look at it.
2answers
Error code c6708
Please send me konica minolta bizhub 600 full service manual and help us this code c6708 still and my next machine bizhub 750 still warming up why problem this machine please help and send me your email address.
i want to talk to you continuous
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
