Error P21
SOURCE: konica minolta EP2010 error code c05
I have a Konica Minolta CSPRO EP1054 (in the Middle East)
I accidentally plugged the EP1054 copier into a 110V outlet instead of
the 220V. Immediately the malfunction code (error code) of "C05"
appeared along with the "Call Tec Rep" indicator light (wrench).
I followed the instructions posted by "Soul Visitor" ... i.e., I found
the "Trouble Reset Switch" (not shown in the user manual) by opening
the upper back panel and pressing the small black button in the lower
right hand corner of the middle circuit board (green).
It worked perfectly!
SOURCE: How to setup scan to pc on Konica minolta bizhub 350 Error ED09C7
Your configuration sharing SMB folder is incorrect. Create desktop folder rename all upper case SMB right click on the folder and click sharing and set full control to everyone. Go to web brouser type in the ip address of the printer log on to administrator password 8 zeros or 12345678 and change the setting.
SOURCE: error c2557 konica minolta 250/NEC IT2530
Reset it, start it with the right door open, go to service mode, clear the counters for drum and developer and go to functions menu. Close the right door and start immediately the F8 function. It should work.
SOURCE: Konica Minolta Magicolor 4690MF gives 0502 error.
machine trouble 0092 service call
This happen after I cleaned the waste box for Konica Minolta Magicolor 1600W
