SOURCE: dsc-w80
remove the battery and press and hold the power button for a min. then reinsert the battery and turn the power back on and then try to change the language again.
please post me a message if it worked
avaya ****
maimai alovera
SOURCE: need english translation of zoom H4n handy recorder
You can download the English manual from:
http://www.zoom.co.jp/english/download/manual/english.php
Direct download link: http://www.zoom.co.jp/archive/English_Manual/E_H4.pdf
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks
Testimonial: "Guru, thanks for taking the time to send me the information on downloading the instruction manual!"
SOURCE: how to convert my walkman sony digital media
contact the manufacturer, explain problem, say PLEASE
SOURCE: translating japanese to english on fuse box
is located under the dashboard on the driver's side. The fuse label
is attached under the steering column. If something electrical in your
vehicle stops working, check for a blown fuse first. Below table
outlines detail fuse number, its ampere and circuits protected.
No.
Amps
Circuits Protected
1 2 3 4 5 6
7 8 9 10 11
12 13 14 15 16
17 18 19 20 21
22 23 24 25 26 27
28 29 30 31 32
33 34 35 36 37
38
7.5 15 10 7.5 (15)
(20) _ 10 7.5 7.5
10 10 10 7.5 7.5
10 10 20 15 7.5
20 _ _ (20) 20
20 (20) 15 15 20
(15) 20 20 7.5 7.5
10 7.5 30
Power Window Relay Fuel Pump ACG
ABS/VSA Heated Seats* Front Fog Lights*
Not used Rear Wiper ODS (Occupant Detection
System) Meter SRS Right Headlight High
Beam Left Headlight High Beam Small Light
(Interior) Small Light (Exterior) Right Headlight
Low Beam Left Headlight Low Beam Main Headlight
High Beam Small Lights MAIN TPMS
Headlight Low Beam Not used Not used
Moonroof* Door Lock Front Left Power Window
HAC Option Rear Accessory Socket Accessory
Front Right Power Window Accessory Power Socket on
the Center Table* Rear Right Power Window Rear
Left power window ACC Radio ACC Key lock
HAC Daytime Running Lights Front Wiper
SOURCE: i have a Toyota Harrier
ask from the Toyota for English version or do translation by some one
