How do I use the buttons in this QHY watch?
Hopefully, this will help...
Lego Watches Manual Instruction:
There are 4 buttons on this lego watch case, Light button, Mode button, Stop button and Reset button, now I will show how to set the time easily!
1, Light Button: Press this button, the watch LCD light will display for 3-5 seconds;
2, How to use the stopwatches chronograph function?
Answer: When the lego watches in normal working condition, Press "Stop button" for 1 time, then the watch goes into the chronograph mode, then you can use "Stop button" and "Reset button" to operate this function.
3, How to set the alarm time?
Answer: When the lego watches in normal working condition, Press "Stop button" for 2 times, then the watch goes into the alarm mode, then you can use "Stop button" and "Reset button" to set the alarm time, also you can turn off or turn on the alarm function and chime on every hour function by the same operate.
4, How to set the right watch time, hour, minute, second, week, date, month, year?
Answer: When the lego watches in normal working condition, Press "Stop button" for 3 times, then the watch goes into the time setting mode, then you can use "Stop button" and "Reset button" to set the second, minute, hour, week, date, month and year.
This is all. So now please have a try to set your lego watches time!
It's off the track. I decided to repair one that I bought used off of Ebay because I got it for a good price. After disassembling the chair down to the base, remove 6 screws that hold the top of the base and remove it. Then unscrew 22 screws from the bottom (18 around the perimeter and a set of 4 in a square towards the front.) This will allow the bottom to separate from the top (the piece that covers the LED screen and knobs). Look under the remaining part of the base to release 4 clips (looks hard and long, it took me awhile to figure it out). You'll be able to see the motor once you get this part off. Notice the four wheels that run on top of metal bars. Check to ensure they are all on top of the bar. One the one I bought, one wheel was off. Unscrew thewhite plastic piece that corresponds to the wheel that is off track and place the wheel back on the bar. Screw the piece back on and plug in to test movement. Hope this helps!
105 people have viewed this problem!!!! I say it's recall time for the $300 seat!!!!!!
Hi
My name is Lola and I am from Sydney Australia
I purchased 4Moms Mamaroo Australia and we had a trouble with the bluetooth and i contacted them to solve it they did it in 3 working days
I would love to recommend
https://www.rushk.com.au/4moms
