TI calculators have an annoying habit of dimming the screen, especially when the batteries are changed, so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
Hello, Well, if screen shows the RAM CLEARED message, that means your calculator is working. Just press the [CLEAR] key, message will be erased and you are ready to crunch numbers.
You say you changed the batteries. Did you also change the back up battery? It's located in a little door with a screw right above the AAA batteries.
My students have come to me many times and have said that their calculator will not turn on. Most times it is that the contrast on the screen has been turned down and the calculator is turning on but the screen is too dim to see that it's on.
To check your contrast, turn the calculator on, press the 2nd key and the up arrow. This is how you darken the screen. You lighten the screen the same way but you use the down arrow instead.
These instructions are from education.ti.org, and worked for me.
1) Take out one of the AAA batteries
2) Hold down the CLEAR button
3) Put the AAA battery back in while still holding down the CLEAR button
4) Let go of the CLEAR button and turn the calculator ON
5) Press CLEAR to get rid of the error message.
Then you should be good! All the applications on my calculator were still intact, so despite the error message, the RAM was never actually cleared.
TI calculators have an annoying habit of dimming the screen when the batteries are changed. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
