HP 5590 ScanJet Flatbed Scanner Logo
Posted on Apr 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HP 5590 - cannot scan and save doc directly to jpeg format
I need the scanned documents be saved as jpeg instead of tiff, pdf or rtf.
  • Anonymous Mar 14, 2014
    cannnot scan and save doc directly to pdf
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 13, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1491
Points
6
I need the scanned documents be saved as pdf in HP scanjet 5590
Anonymous
Level 1:
New Friend:
  • Posted on Sep 14, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1491
Points
No solution, but I have the same problem now that I am on Windows 7. I also cannot scan 2 sided anymore. There is no option for it
HELP!!!
Anonymous
Level 2:
  • Expert 134 Answers
  • Posted on Apr 27, 2009
Anonymous
Expert
Level 2:
Answers
134
Questions
Helped
64853
Points
462
FineReader can scan documents and save it as jpg.
Download it from here
Hope it helps.
When I scan a document and choose 'save a copy' to the desktop, it is in pdf format. Instead I need to scan and have jpeg. How do I do this?
  • open hp director (click on the hp director icon) on the computer
  • select the option SCAN PICTURE to automatically set output type to jpeg
  • if that does not work,click on settings on the top,scan settings and preferences,select scan document settings or scan picture settings or the scan preferences menu
  • change output type from there
2helpful
Put scanned document on my computer to print afterwards if necessary and read on my computer
I am unclear on your problem but in general..you use the scanning software that came with the scanner scan the document and save the scanned file to your computer as a pdf file for documents or tiff or jpg for photos, (you set the type of file you want to save with the software options)
To print afterwards open the pdf with acrobat and print it
Did that answer your question?.
1helpful
3answers
New all in one printer/scanner. when I scan I get:- Adobe reader could not open 'scan_Doc0001.pdf'
Might need a bit more information about this: But I'm presuming you scan your document and save it as a pdf document using the built in HP software?
Couple of things to try:
1 - have you got the latest version of Adobe Reader? It may be that you are using an older version - the pdf document specification has been updated over the years and it may be that you're saving the pdf using a newer version of the pdf format than adobe reader is able to read.
2 - Adobe reader isn't the only pdf viewer, there are numerous other pdf document viewers (some free some not) You could try another pdf viewer, like Foxit Reader (free to use) and see if that can open it?
3 - When you save the scan, make sure that in the Save Dialog box it is really saving it as pdf. Common mistake is that people often just save a file with .pdf and expect the program to know that you want to save as pdf. When you scan there are several other file formats that you can use (Tiff, Jpeg etc) Is is possible you're saving the file as Tiff or Jpeg but with a .pdf file extension? If you're not sure, re-scan the document and resave it, but don't use a file extension, let the scanning program do that, see what it saves it as?
4 - check where you're saving the pdf on your computer? Is the place you're trying to open it from, the same as the place you've saved it?
4answers
How to convert scanning documents to MS-words
You are going to want to find any OCR software that works for your printer. OCR is 'Optical Character Recognition'. It will take the scan and convert it into a text document, which is either already compatible for MS Word, or easily converted itself.
When I scan a document it outputs as a TIFF file which is very large. How can I get it to output the scan into a JPEG files instead. It used to do this, but now it does TIFF and I'm not sure why.
INSTALL PRESTO MANAGER IN THAT ICONS WILL BE THERE LIKE PAINT MS WORD JPG TIFF PDF CLICK THAT ICON AFTER SCANNING SCANNED IMAGE WILL BE SAVED IN REQUIRED FORMAT
How can I scan a document into the WorkCentre M20i so that it is emailed as a word document and not a PDF doc. When we scan a document it is emailed as a PDF document.
You can not email documents on word format directly fromt he device.
PDF and image formats such as tiff and jpeg are the only formats you can scan.
A word document is a raw document that as been modified and formated by a specific text processor, in this case MS office. And the decive does not contain this processing capabilities.
1helpful
Pdf and jpeg format scanning problem in Canon iR2018 copier
Yes,you do have to buy the sent kit.But remember the sent kit Scan to e-mail and not directly to the computer.Your company have to have a mail server to be able to work properly.Adobe have software that you can buy that chance word document to PDF.
4helpful
3answers
Cannot scan to pdf Deskjet F2100
You have to scan with Adobe Reader in order to scan and save a pdf
k24674
Grand Canyon Tech
Grand Canyon Tech
