Your front spring rate and fluid is most likely set for city riding. For softer sealed roads.
From what I can search, it looks like it is 10W oil. Maybe go up to 15W fork oil and see if that stiffens it up enough. Don't go for the highest rating,as you'll just cause damage and possibly injure yourself in the process. Always do it incrementally.
most street bikes come with the option of being able to stiffen or soften the forks via screws on top of the handle bar clamp, specific instructions can be foiund in your manual or on cbr forums
Sorry to inform you, but there is no adjustments available for the forks that come with your bike. Adjustable forks (just the fork) start in around $250-.
On the positive side since there is not adjustment capability the fork does not need regular servicing like the adjustable forks.
Hello the locking nuts on the shock are preload adjustment, turning them to move in the down direction will stiffen the suspension but not actually raise the height of the motorcycle but you will have less sag when you are on the bike by adding more tension.
If it has air caps on the top of the forks, you can put a little air in them. If not, the other thing you can do is add a bit more oil to each fork leg.
there r hundreds of heavy duty and off road companys that sell heavy springs /anti sway bars /axles everything and anything check the advertisers in off road /and truck magazines as well as online for what u want
