Replaced regulator and now i get bleeding thru the regulator when the tank is full and no airline is attached....when i hook a airline up the air stops leaking....why ?? replaced old regulator and that one now bleeds thru also....never had this problem before i replaced the old regulator now they both bleed don't get it....any hep would be appreciated.
thanks..
This problem is not uncommon with small compressors and the inexpensive plastic regulators they use nowadays. The one surefire way to stop it is ti install in in-line valve before the regulator outlet, even if it involves the double ended & threaded brass soupler so they both fit on. This way you can just turn the handles across the line effectively shutting off air flow. I have two pancake compressors and ended up doing the very thing.
Then when time comes to hook up a hose and tool, just switch the handle back and you have air.
Sirwriter
Try a better quality quick connect
Most cheap female quick connects use a cheap rubber or EPDM seal that will leak over time. Replace the quick connect and that should solve the problem.
