You apparently have your calculator set to display no digits to the right of the decimal point. 5/2 is 2.5, which rounds to 3, and 50/100 is 0.5, which rounds to 1.
To change the display setting, press MODE, highlight the desired settings on the first two lines, then press ENTER followed by 2ND QUIT. Try setting "NORMAL" and "FLOAT" and see what results you get now.
SOURCE: Linreg
enter your data into L1 as x-coordinates and L2 as y-coordinates at (STAT) + (EDIT) and then turn on your StatPlot. Finally, press (STAT) ->(CALC) -> (4)LinReg(ax+b) and (L1) (,) (L2) (Y1)
nb: Y1 could be find from (VARS) -> (Y-VARS)->(1:Function...)
SOURCE: TI-83 Plus No Longer Squares Correctly
when you type -2 imagine your calculator doing the equation: -1 x 2. The - sign actually stands for a -1 so when you do -2 squared your calculator is simply following order of operations. It first squares the 2 making it 4, then it multiplies the negative making it -4. In order to get around this you must use parenthese. (-2)^2.
Hope this helped
SOURCE: My TI-84 Plus gives answer as 2.145274703E14, what Is E?
E is the calculators form of scientific notation. so 2.145274703E14
is really 2.145274703 x 10^14 or 214527470300000
