Kenmore 22422 Top Load Washer Logo
Julia Hann Posted on Aug 18, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ok, I have a used Kenmore 70 Series Heavy Duty washer. The model number is missing, so I can not provide that. It will fill with water, then just stop. No motor noise, no clicking or humming, the knob doesn't advance, nothing. Occasionally, I can advance it to spin and it will spin and empty the water, but not always. Any ideas? Is it worth fixing or should I junk it and get another one?
paul
Level 3:
  • Master 825 Answers
  • Posted on Aug 18, 2017
paul
Master
Level 3:
Answers
825
Questions
0
Helped
174003
Points
2202
Needs new brushes on the motor.....
cheers
2 Related Answers
Anonymous
  • 109 Answers
  • Posted on Jun 16, 2009
SOURCE: series 70 fills wit water stops then makes a slight buzzing sound
The electric motor my have failed or a part called a capacitor could be the problem? The capacitor is part of the starting circuit of the electric motor, if this fails the motor will not start therefore the washing machine won't spin or agitate.
Anonymous
  • 1937 Answers
  • Posted on Apr 22, 2010
SOURCE: model 22748 kenmore 70 series washer. fills but
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.92274800&pathTaken=partSearch
and you'll see a list of major sub-components with diagrams and parts.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump. This is likely why the machine drains.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
It is also likely the source of the burning smell.
(Sears price $18.86 but available from most appliance repair shops)
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Kenmore Heavy Duty Series 70 washing machine will not spin during draining, but makes a lot of noise like gears grinding. What's the cause and can it be repaired at a reasonable cost?
It could be the clutch or the gearbox. It can be repaired, but top loaders are old dinosaurs these days. Front loaders are as big or bigger, and more efficient and cost a fraction of the cost to run in water and electricity for heating that water.
Series 70 is just that, a series. A model number will give you the cost of spares and how many have been discontinued?
https://www.google.com/search?q=Kenmore+Heavy+Duty+Series+70+parts
70 Series Kenmore Washer Agitates in Heavy Duty regardless of switch selection
Yours is a 2 speed motor. Does it spin in 2 different speeds. If so, then it most likely is designed with only to agitate in 1 speed. If it only spins in one speed, then your motor is defective
1helpful
Kenmore heavy duty 70 series model 110-8237012
probably your drain pump leaking it has a seal right where it attaches to motor,,,,mine is leaking there but haven't replaced it yet! lol
Kenmore Heavy Duty 70 Series Leaking in the back
If you bought a new washer and you still have a leak, i guess it was not the washer but where it drains into. Sink or stand pipe has a leak. unless you are useing the old drain hose from your old washer. Dry up everything and look for the sorse of water with a bright light when the washer drains .
2answers
I have an old Kenmore Heavy Duty 70 series washer.
its a filter inside the water hose thats still blocked or the relay inside the washer for the cold feed is not opening up fully it could just need a clean or maybe a new one fitted
31helpful
2answers
What is the date of manufacturing based on the serial number of my Kenmore 70 series washer?
Tyler,
It came off of the Clyde, OH production line the 26'th week of 2001.
Amazing, ain't it? Seriously... the info is embedded in the serial number. Here's the link to the code sheet.
Please remember to rate this solution as "FixYa", OK?
SG
4helpful
Slow cold water only fill kenmore heavy duty 70 902202
remove fill hoses and inspected for debris or cloggs ,,,,
4helpful
3answers
Kenmore heavy duty washing machine 70 series
The most likely cause for water fill temperature problems is the solenoid has burned out, usually cold first, it gets used more. Not a repairable item , easy to replace
Alexander
vince
