SOURCE: WCVH6800JMS pauses mid-cycle: I
The error code E22 is the most recent fault recorded and you are correct. It pertains to a fill time exceeding 8 minutes and can be due to a faulty pressure switch not tripping to signal the control that the correct water level has been reached.
Test t06 is where the water level control, the pressure switch for that matter, is being tested. Pump runs and displays E at start if no water in the tub. Press Start/Pause to advance and water valve begins to fill. Displays F when reaches FOAM level. Displays nl when reaches MAIN level, and briefly displays oF when reaches overflow level, then pumps water out. Displays E when empty. If it keeps displaying E, the pressure switch is stuck in the empty position.
Remove the 3 Phillips-head screws that attach the top cover, then pull the cover rearward. Remove the 3 (7-mm) hex-head screws that attach the rear of the top panel to the cabinet. Slide the top panel about an inch rearward then lift the panel.
On the right side of the machine cabinet facing the front is the pressure switch.
Check the connection of the pressure tube with the pressure switch and the bottom of the tub and make sure there's no air leak or kinks which can prevent pressure built up to trip the pressure switch. Remove the pressure tube by squeezing the clamp then slide it back. Carefully break the hose loose by inserting a small flat-blade screwdriver under the hose to break the seal. Remove the pressure switch by pulling its bottom then rotate it 1/4-turn clockwise to clear the suspension
spring.
Blow air forcefully down the hose to clear it and do the same through the pressure switch inlet to possibly free a possible stuck contacts. Replace the pressure switch with part number WH12X10307 if the problem persists.
Please accept the solution
should you find it helpful and/or informative. Accepting the solution will not stop you from
posting comments or additional information. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Hello Mary Fortner - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
