SOURCE: Graphing a set of points
First click on the Y= button and enter an eqation or goto stat and hit enter and type the points. Afterwards goto Y= then hit plot1 so it is highlighted and hit zoom and then zoomstat and you will have grphed your points.
SOURCE: I can't graph on my ti-84 plus silv. edition
More than likely, you've put in a number in the xmin or xmax that is not correct. Example....you put in an xmin of 10 and an xmax of -10 which would be backwards. This could also happen in the ymin or y max.
The easiest way to fix this is to press zoom 6 which wil get you back to the default graph of xmin of -10, xmax of 10 and ymin of -10 and y max of 10.
If you can't see your graph on this screen and need to change the window, just be sure the number in the min for both x & y is smaller than the number in the max. You change your window size by pressing the window button.
SOURCE: i cannot graph more than one line with ti-84 plus
abe dust pair uper kar de problem solve ho jayega
SOURCE: My TI-84 Plus Silver Edition
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Well...It did show a graph but not the graph of table list but the graph of a function that I had graphed before
Well ... It's still cannot work..thanks, anyway.... I need to reset my calculator for that I try so many ways on it, and i just got more confused on it......
