Im trying to update the os on my ti nspire with ti 84 silver plus on it but when it begins it only says transfer error can i do anything about this? It lets me download the new os but doesnt actually allow me to send to my device.
The standalone version of the OS for the TI84Plus/TI84Plus SE are not
for TI-Nspire with TI84 keyboard. The 94 Plus part of the TI-Nspire is
updated when you update the OS of the TI-Nspire. The version numbers are
different.
To update you TI84 portion of the TI-Nspire, update the OS for the TI-Nspire. Thy are now at Version 3.2.3.1233
SOURCE: error message for TI-84 Plus
Try and resolve this issue by re-installing the calculator's operating system using the TI OS Downloader. To do this, please follow the steps listed below. Be sure you have fresh batteries in your calculator.
1. Download the OS 2.43 file to your computer (preferably the desktop).
2. Open the TI OS Downloader by going to Start>>Programs>>TI Tools>>TI Connect>>TI OS Downloader. If you do not see TI OS Downloader, you may need to install the latest version of TI Connect. You can download a free copy from:
www.education.ti.com/downloadticonnect
3. From the main screen, select your calculator and cable type. Click "Next" to continue.
4. From this screen, locate the OS 2.43 file by clicking on the yellow browse folder and navigating to the location where you downloaded it. Double-click the OS 2.43 file to select it.
5. Remove one triple A battery from your TI-84 Plus. With the battery removed, press and hold the [DEL] key while you re-insert the battery.
6. You should see a "Waiting..." message on the screen of your calculator. If so, disconnect the USB cable from your computer, re-connect it and then click "Start Download". This should begin the OS transfer process.
SOURCE: I have issues turning on my TI-Nspire using TI-84 Plus SE keypad
i would say use the normal key pad or send it in to T.I to fix.
SOURCE: my TI- 84 plus had
you canot fix this problem
the calculator need Hardware Reset
i can fix this problem let me know if you want to fix
[email protected]
Jack
SOURCE: can you transfer ti83 os to ti 84?
The TI83Plus has the capability to transfer its OS to another handheld device. It is possible that the TI84Plus hardware will accept it. But why downgrade?. Why not resinstall the OS? The latest version 2.55MP is available on the TI website.
You say emphatically that you tried everything and maybe so, but I will ask you: Have tried to connect the calculator to a computer and explored its content with TI connect. You may retrieve some information about its status.
The TI connect software will allow you to transfer a version of the OS even if the calculator appears to refuse to turn ON (screen contrast problem.) If it cannot it will let you know.
Try again.
Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display
"Waiting...Please install calculator software now". If calculator did not turn on or, is still locked up goto Procedure 3, unless already did Procedure 3, then goto Procedure 4. If you calculator does come on and is responding and, your connect to another calculator goto Procedure 1. If you calculator does come on and is responding and, your connect to a computer goto Procedure 7.
Procedure 3.
Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary. Goto Procedure 2.
Procedure 4.
If the above process did not work. Try re-doing the Procedure 2, and, this time extend the time in Procedure 3, by 5 minutes to 10 minutes before you put all the batteries back in the calculator. These calculators can be a little stubborn at times so, keep trying Procedure 2.
Procedure 5.
If you can't find a calculator to connect too, you can connect your Ti 84 Plus to a computer that has Ti Connect software on it. If you need to connect your Ti 84 Plus to a computer make sure the Ti Connect software is operating properly. You do not want any hang-ups while installing the Ti 84 Plus OS.
Procedure 6. Procedure to installing the latest Ti84 Plus 2.55v. MP OS. TI OSDownloader does not always install the latest OS.
You can get the latest copy of Ti84 Plus 2.55v. MP OS and, guidebook by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 84 Plus 2.55v. MP OS!" Once your at the Ti site click the Download Item, "Ti84 Plus family operating system". Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti84 Plus family operating system will download to you.
Next, click "SAVE" and then a window to a folder will pop up. It is probably a window to a folder that you download too. If so, you may want to change it and, save to this folder, "My Documents \ My TI Data \ Downloads". You can also go back and, download the Ti 84 Plus guidebook too, if needed. If your calculator will not turn on or, is locked up goto Procedure 2. Or else goto Procedure 7.
Procedure 7.
Important Note: Never disconnect a TI Connectivity Cable during a transfer. Lost of power during installation of OS will destroy your calculator.
Link your computer and, Ti 84 Plus calculator with the USB cable or, Direct Black Link cable that came with the Ti 84 Plus calculator. Next, drag the Ti 84 Plus 2.55v MP OS that you saved earlier in "My Documents \ My TI Data \ Downloads" out of that folder and, drop it in the "Ti Connect" icon on the desktop. Click, "Continue" when the "Erase Warning" pops up and, the new Ti 84 Plus 2.55v MP OS will begin to install. Next, the Ti Device window should pop up and, highlight the port when it finds what your Ti 84 Plus is using, USB1 cable or, Direct Black COM1.
When the Ti Device Explorer finds and, highlights your calculator's information click, "Select." Then click, "Yes" when the next window shows up with your calculator's information and, the OS will continue to download. Upon completion the newest Ti 84 Plus 2.55v. MP OS will be installed.
If you run into any trouble with software or, drivers just comment to what failed at this posting and, I'll be glad to help you.
