When i turn the key nothing happens. change battery and still no power.
Old posts zero answers. what year, no year stated.?
great post, Key does nothing" clear
and is called NO CRANK, if it cant crank it cant start (m/t push starting might)
any time its a no crank,
check ALL FUSES.
1: if A/t wiggle gear shift (P then try Neutral) N might work.
2: if M/T , wiggle clutch , near floor pressed.
if CEL lamp is dead, key on, the fuses are blown.
the CEL must glow key on, or Fuses blown.
easy huh?
SOURCE: Full power won't jump nothing happens when I turn the key
Sounds like the starter has failed. Have someone turn the ignition while you tap on the starter with a hammer. If it starts, that confirms starter. If it still doesn;t start, remove the stater and have it bench tested at a parts store.
SOURCE: when I turn the key, nothing happens. battery is
your starter needs replacing not to hard of a job to do yourself
SOURCE: The battery has power, but when the key turns,
Hello: If the security light is flashing when you try and start the truck you have a passlock problem.
SOURCE: won't start
could be the neutral switch try and crank it while moving the shifter around also try and put power to the small terminal on the starter that will tell you if the starter is bad or the wiring or switches
