Imri Azar Posted on Sep 22, 2013
Is there a universal standard for hole punchers?
karl
Level 1:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
New Friend:
  • Contributor 22 Answers
  • Posted on Sep 22, 2013
karl
Contributor
Level 1:
Mentor:
New Friend:
Answers
22
Questions
25
Helped
14706
Points
71
No there isn't, there are many different hole punchers that make holes at different spaces apart and different countries use different hole spacings.
Wikipedia has a chart of all the different hole punchers. http://en.wikipedia.org/wiki/Hole_punch#Chart.5B3.5D
Remove stuck screw from crankcase coveron '83 Honda c110 motorcycle
Hi! if you don't have a hammer-screwdriver (what is the right name?) just use a puncher + hammer: on the side of the head first punch a small hole, so the tip of the puncher is well held on that spot/hole. Then carry on with the puncher a bit off-axis (of the screw), to cause the screw to rotate a bit to the left. Then carry on. Some WD40 can help too. I got some great results like that. Good luck!
Magazine tray button stuck
Hello, GO to this website for phone number support and to download manual for this product. Bostitch Office Products Staplers Pencil Sharpeners Hole Punchers Tools...
Is there such thing as an electronic hole puncher?
Yes there are a lot of electronic hole punchers, you can find them at stores like Office Max and Staples.
My Lavazza Blue coffee machine does not press enough to punch the holes. The coffee comes out water. What should I do.
After 1700 shots it is recommended that both upper and lower punchers as well as all seals in the brew unit be replaced. These punchers are only plastic so they do get worn down after much use. You may also be experiencing more water in your drawer as water is leaking from around the capsule seal. This is also an indication that the seals and punchers should be replaced. Given where you go to have this fixed, the parts may cost less than $15.00.
Printing
The Phaser 7400 starts at $2,799. see models and prices see cost per print Color: up to 36 ppm Black: up to 40 ppm First-page-out time as fast as 12 seconds 800 MHz PowerPC processor Maximum paper size: 12" x 18" All models come standard with 10/100Base-TX Ethernet connectivity Standard paper input capacity: 800 sheets Maximum paper input capacity: 3,000 sheets Finisher/stacker/stapler/hole puncher capable of handling up to 1,000 sheets Maximum duty cycle up to 150,000 pages per month What comes in the box show/hide contents Color toner cartridges (capacity: 9,000 pages each 1 ) Black toner cartridge (capacity: 15,000 pages 1 ) Imaging units (capacity: 30,000 pages per color 2 ) Waste cartridge (capacity: 30,000 pages 2 ) Fuser (capacity: 100,000 pages 2 ) Transfer unit (capacity: 100,000 pages 2 ) Finisher ships with 5,000 staples Power cord Software and documentation.
k24674
ADMIN Andrew
ADMIN Andrew
