Imri Azar Posted on Sep 22, 2013
Are there hole punchers that make different sized holes?
1helpful
Do deadbolts come in different sizes for inset (holes) in door? Deadbolt I bought needs 2" hole, I need one to fit a 1.5" hole.
Schlage B60 Single Cylinder Grade 1 Deadbolt
They come in that size . Google deadbolt for 1.5 inch hole
Remove stuck screw from crankcase coveron '83 Honda c110 motorcycle
Hi! if you don't have a hammer-screwdriver (what is the right name?) just use a puncher + hammer: on the side of the head first punch a small hole, so the tip of the puncher is well held on that spot/hole. Then carry on with the puncher a bit off-axis (of the screw), to cause the screw to rotate a bit to the left. Then carry on. Some WD40 can help too. I got some great results like that. Good luck!
Magazine tray button stuck
Hello, GO to this website for phone number support and to download manual for this product. Bostitch Office Products Staplers Pencil Sharpeners Hole Punchers Tools...
Is there a universal standard for hole punchers?
No there isn't, there are many different hole punchers that make holes at different spaces apart and different countries use different hole spacings.
Wikipedia has a chart of all the different hole punchers. http://en.wikipedia.org/wiki/Hole_punch#Chart.5B3.5D
Is there such thing as an electronic hole puncher?
Yes there are a lot of electronic hole punchers, you can find them at stores like Office Max and Staples.
My Lavazza Blue coffee machine does not press enough to punch the holes. The coffee comes out water. What should I do.
After 1700 shots it is recommended that both upper and lower punchers as well as all seals in the brew unit be replaced. These punchers are only plastic so they do get worn down after much use. You may also be experiencing more water in your drawer as water is leaking from around the capsule seal. This is also an indication that the seals and punchers should be replaced. Given where you go to have this fixed, the parts may cost less than $15.00.
Dryer makes small holes (cigarette burn size) on clothes
Get a new dryer. Old ones tend to tear-up clothes and burn holes.
Apr 29, 2009 • Dryers
k24674
ADMIN Andrew
ADMIN Andrew
