SOURCE: how do i fix the error message MACHINE TROUBLE
1. Main switch is tuned ON.
2. Press the following keys in this order
2 -> 6 -> 2 -> 7 ->3
3. Main switch is tuned OFF/ON
SOURCE: error F32
the error is COF32. You have to check the developing unit, to change the developer is needed and to run atdc auto adjust.
SOURCE: please i want to know if konica minolta magicolor
The Konica Magicolor 1690MF Printer/Copier/Scanner is connected with an Ethernet Cable or USB Cable. It is not equipped to operate as a wirleless printer. It has a 10Base-T/100Base-TX Ethernet interface port and a USB Revision 2.0 High-Speed compliant port.
To do two-sided printing you must have the duplex (double-sided) option installed. This also requires either Tray 2 or the Attachment to be installed underneath your machine. Tray 2 is the optional lower feeder unit which increases capcity of your machine to 500 pages. The Attachment comes with the Duplex Unit.
Only Letter and A4 plain paper (16-20 lb bond) can be autoduplexed. With the duplex accessory installed you can do duplex or double-sided printing automatically.
From within Printer Preferences select Two-side Printing > Automatic. Shoud have choices of Off, Manual or Automatic. Within the Layout Tab for your work you may also be able to specify duplex (double-sided).
Should you have continued difficulty, please reply and advi e if the duplex option is installed and with which software and operating sysytem you are using.
Thank you for using FixYa!
CAUSE: The transfer belt is not rotating correctly inside of the Image Unit.
SOLUTION: Check the PRCB connector for proper connection and correct as necessary. Also, check Belt Positioning Sensor (PS6). Replace Image Unit (p/n A0VU011). The PRCB may also need to be replaced. (p/n A034 H001 06 for magicolor 1650EN or p/n A034 H009 07 for magicolor 1680MF/1690MF)
SPECIAL NOTE: Solution contribution by SSD Printer Support
ID No.
TABP1000085EN
FROM KMBS SSD
