I assume you are referring to the deck bearings. The easiest way to replace the blade drive bearings is to remove the deck from the mower. You can then easily remove the blades, clean the deck and be able to easily get to the bolts holding the bearings and pulleys in place. This is normally a straightforward repair and can be accomplished with common hand tools. You will need to purchase the parts from the dealer who sells the mower. Replace all 3 set of bearings. On a 3 year old mower ask yourself why the bearings failed. Are you washing under the deck when the bearings housings are hot? That will cause premature failure. Are you greasing the bearings regularly?
