Bosch WET 2820 Front Load Washer / Dryer Logo
A
Anonymous Posted on Sep 18, 2013
Bosch wet 2820 manual - Bosch WET 2820 Front Load Washer / Dryer
I have a Bosch 2820 and the water once it starts filling won't stop. Is this a malfunction of the inlet valve?
No its the water censor located inside the machine is blocked,remove back cover you will find a small plastic pipe leading upwards,remove it and clean out the lug it came from with a ear bud or other un sharp device the pipe as well,gently blow into the pipe you should hear a clicking sound this is the water level indicator to the programmer to stop filling, replace it carry on washing eric992
Broken belt
Buy new belt for washer, pop off back plate, put new belt on.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Hi! re BOSCH washing machine WET 2820 Program will start, and then for 30 secs approx start normally, water starts to enter the drum. Then it stops, nothing happens. I have cleaned the soap dispens
BOSCH washing machine WET 2820 This video will show you how to change the door eal washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
I don't know to use. I need a manual instructions of WET 2820.
I'm so sorry but this forum is not able, nor in a position, to supply any type of manual, parts list, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
Also members on Fixya are not 'affiliated' to, or representative of, any manufacturer at all, just using their experience gained probably over many years.
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
2answers
Water leaks in all programs
Bosch WET 2820 Front Load Washer / Dryer water
Leaking.
This video will show you how to change a door seal on this Bosch front loader washing machine .
we have all bosch repairs in our channel
I have a Bosch WET2820 washer/dryer and if I am away from home for a week, water starts to assemble in the interior of the machine and the moisture starts to smell badly. I select the drain programme, but...
the water inlet valve is letting the water by, you will need to fit a new one. to get the correct part number you will need the model number which u already have and the "FD" number to get the specific model as there are a couple of varients. you should find the fd number on the silver rating plate inside the door
3answers
Bosch WET 2820 dryer pumps in water
most likely a electrical fault have programmer checked
7helpful
2answers
WET 2820 programs
I have noticed on bosch website that WFT2806 is exactly the same model and there is a manual to download.
go to http://www.bshappliancecare.com/Bosch/ and select instruction manuals then search for WFT and wait, the page will authomatically redirect you to the manuals for WFT2806GB which I think is the free standing version of the washer.
enjoy.
Tumble dryer not working
I managed to solve the problem the following way: I noticed that if you unplug the Sensor-NTC(part nimber 154431 https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=WET2820GB%2f13 ) that controls temperature of air in the air channel, the drying cycle runs as you describe above. So this circute was checked up to the power module. Contacts of the Sensors plug were tightened; I think this solved the problem; resistance of the sensor checked. It must be 4.8K at 25 degree C. and decrease when temperature increases. I dipped the sensor in a glass with hot water.
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
