see this causes and fix it. God bless you
Makes to much ice or won't shut off.
Check shutoff arm. This may be hung up on ice or food item.
Makes no ice.
Check shutoff arm. Check to make sure it is getting water, check water
solenoid. Check water supply line it may be frozen or plugged up. Check
freezer temperature to low of a temperature could cause the line to
freeze up. Check for power at motor. You will need to
remove the ice maker. Find the leads that go to the auger and connect a voltmeter. Press the dispenser lever you should have power if not
replace the control board or micro switch.
Check control switch or microswitch. Put icemaker in test mode. Only some are equipped.
Ice cubes to large or small.
Adjust size by removing cover and turn adjustment screw + or -.
Check water solenoid. Check water supply line. Make sure it is level.
Ice tastes bad
Clean ice tray. Check supply line. Check water solenoid. Change filter.
Run at least a 3 gallons of water thru the line after replacing filter
this will flush all old water.
Ice is discolored.
Check water solenoid. Check supply line. Change filter. Clean ice tray.
Most ice maker problems require either
replacing the ice maker unit or the
ice dispenser control board or
micro switches.
