SOURCE: konica minolta pagepro 1350w error light won't stop flashing
pleas install status monitor, it will tell you what is wrong
SOURCE: konica minolta 1350w status display comes on at start up
Open c:\windows\system32
find a file called MSTMON_Q.EXE
right click and rename the file to anything with a file extension .exe, I named it MSTMON.EXE
Create a shortcut to this new file in case you need it in the future and put the shortcut on your desktop
also, write the original name of the file down or put it on notepad, in case you want to change it back.
restart windows
SOURCE: After replacing black toner cartridge printer displays Drum Low
Ask you companey that surives you printer to look at it
SOURCE: konica minolta pagepro 1400w paper jam
have you tear the paper when removing? there is a small paper left still inside the paper path. open the back side and the top part and check for small paper. I hope that will solve your problem and if think the problem still there the problem is one of the paper sensor actuator is broken or out of place.
SOURCE: Konica Minolta Pagepro 1350W error light flashes and will not pri
You have to see how the led is blinking and to compare with the table that
explains every blink what means. If you don't have this table, contact me and
I'll send it to you.
Chip reset device
for Konica Minolta Bizhub and CF imaging units
http://www.chipreset.eu
