SOURCE: focus remote key fob not working
this info would cost you £30.+ at ford Radio
Frequency Programming Instructions:
SOURCE: Power locks won't work from remote
No you dont have to reprogram the remotes. Please give as much info as you can about the problem. What is working and not working. Is every other function working with the unit. Is this an after market autostart or OEM (from FORD) or is it one of the vehicle security systems?
SOURCE: lock remote stopped working. changed baterry,
some auto parts stores have a display at the counter where they sell new remotes or fob's. The display has a sensor that lights up when you use your remote. Point the remote at the display and press any button if the light comes on your fob is likely ok. may need to check the receiver. good luck
SOURCE: keyless remotes not working
Try reprogramming the remotes. Here are the instructions for the procedure. Hope it helps. Cobra!
Programming
NOTE: All keyless entry remote transmitters (15K601) must be
programmed at the same time.
NOTE: To program (or reprogram) the keyless entry remote transmitters
into the RAP module, perform the following steps:
Testimonial: "Great advice. This fix worked great. "
