Circles are hard to make, I had a lot of trouble when we decided to put recess lighting into the whole house. I wasn't able to find a tool that does all the cutting for you but what worked really well for me was a Goldblatt Drywall Circle Cutter. It doesn't cut all the way through the drywall, it just scores it so that all you have to do is cut from the center of the circle out to the edge and then snap off the pieces. Saves you tons of time trying to get those round edges to look perfect!
Depending on the size you need to curl, hole saws are a perfect solution! Just need a drill to use it. Or a Dremel with a cutting too makes quick work but that's more for making a specific shape than a perfect circle. And finally, a string and a razor knife is what we used when I hung drywall. Good luck hope this helps.
You may want to consider a Circle Cutter:https://www.bontool.com/circle-cutter-16...
