I don't know why it display the error code 7 and it just stop doing only for a while after i have switched on the machine i don't know what the error code 7 mean.help me with this
Very simple you just press the WATER FLOW button, PRESET button and RINSE button to reset it memory test it out
Status E7 - 4 is protector motor washer there are problem. please your ceck at ; capasitor,load in basket overload,Sensor at drive motor washer faulty it the same as with sensor load cell but it is motion sensor <!-- from fixya rte -->
Asa
SOURCE: i have a Haier XQBM22-C washing machine and it displays error 7
Here's the user's manual: http://service.haieramerica.com/documents/User%20Manual%20XQBM22-C.pdf
Here's the service tec manual: http://service.haieramerica.com/documents/WD-8888-72.pdf
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
Error code 7. No instructions about it and the machine refuses to work
I have a toshiba washing machine Model WA-60X, it doesn't work and it show the error code E7-4. Please help me to fix it.
error code e7-1 appear could you pls tell me what is that means, tks
