How to adjust the analog time on casio edifice module no 5299
please let me know on my personal id [email protected]
SOURCE: Casio Edifice Watch
Here is a link to the manual: http://ftp.casio.co.jp/pub/world_manual/wat/en/qw1310.pdf It says: Hold do the (A) button [the upper-right button] to advance the analog time setting. The analog time will adjust forward at high speed. It only goes forward, so if you miss the proper time, you have to go all the way around again.
SOURCE: Shorten strap of Casio Edifice EF-518 watch
good morning ! thats verry easy to make shorter !just look the possition of arow and push the pin to out use the pointed tool and anvil to releas the pin ! thank you !god bless !....
SOURCE: Adjust-a-Casio-S-1087DY-Watch-Band
On most brands, there are pins that form hinges for the links of strap. You need to push them out to remove links. Usually you would find arrows marked from inside of the metal bracelet which show you the direction in which to remove the pins. You can remove it if you have a small watch maker's screwdriver but you have to be careful. or get one of these ..
http://www.amazon.co.uk/Watch-bracelet-link-adjuster-remover/dp/B001ZKIL2S/ref=sr_1_1?ie=UTF8&s=watch&qid=1254695541&sr=8-1
which should help you to remove the link pins safely without scratching.
SOURCE: Casio Edifice Chronograph Ef539d1avdf Gents Watch
mcdevito75 here, You can contact Casio at 800-706-2534 Optn. 2 for a new owner manual.
SOURCE: CASIO EDIFICE Watch Model #:EF-527D-1AV
you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
http://world.casio.com/wat/download/en/manual/
Use this page to download a copy of CASIO watch manuals in
PDF format.
To download a PDF file, enter the four-digit (or three-digit)
module number marked on the back cover of your watch.
PDF format.
Hi Andy. Having the same problem and can't find any info to adjust the contrast anywhere. Shame as it's a lovely watch otherwise
