I have a ti 83 plus and just recently a solid black line (only takes up one line not down the screen) is in the top right corner of the screen. Theres no problem until I put in enough equations to start a new screen. when that happens the small black line in the corner turns into a full screen of seperate black lines. please help!
SOURCE: TI-83 Plus Problem
Batteries:
Make sure to replace the "battery backup" too the little lithium ion battery
Try Adjusting contrast:
Hold down "[2nd]" key press up or down arrow repeatedly to lighten or darken contrast.
First attempt reseting:
Step 1: Remove all the batteries
Step 2: Hold "Clear" key down
Step 3: Still holding "Clear" key reinstall batteries
Step 4: Still holding "Clear" key press "On" key until home screen is displayed.
Second shot reseting:
remove all batteries including lithium ion (backup battery), wait 3 hours and reinstall batteries.
Third Shot reseting:
Step 1: Remove a battery
Step 2: Hold down "DEL" key reinstall battery
Step 3: Possible msg pops up saying "Waiting ... Please install software" IGNORE msg and take out battery again
Step 4: Reinstall battery do not hold down "DEL" key
reseting will cause the handheld to loose all of its stored memory.
Hope that helps!
SOURCE: TI-83 Plus Went Dead
Has it been dropped recently? The screen may have cracked from impact. Press the Reset button on the back using a ball point pen.
SOURCE: ti 83 plus small black screen?
try pressing 2nd then hold in down arrow to change the contrast
SOURCE: texas instruments ti-83 plus. only have black line on screen
Reset the calculators memory [2nd][MEM][7:Reset][1:All Ram][2:Reset]
If that does not work
You should reinstall the system which you find here
http://education.ti.com/educationportal/downloadcenter/SoftwareList.do?website=US&tabId=1&paneId=2
Use the link below to install TIConnect software
http://education.ti.com/educationportal/sites/US/productDetail/us_ti_connect.html You can also download the latest OS there.
Install TI connect on your computer and run it to open the main Window. Then connect
you calculator to a USB port and, in the TIConnect main window Click
the TIDeviceInfo icon. Software will try to retrieve the info. If it
does your calculator is fine.
If it tells you Device Not found ,
Click communication settings in same pop up window where it said Not
found, and Select Device, Select Cable, Select Port and Click OK..
If
you are lucky and it works, you can reinstall the OS, which can be
downloaded from education.ti.com. You drag and drop the OS on the
TIconnect main window. Calculator must of couse be connected to computer.
If
you have problem with TIconnect, use the calc-to-calc cable to transfer
the OS of a working calculator. Yous should be on Receive mode
[2nd][Link] --->>Receive. (When both calculators are ready hit
enter.) The other calculator, you guessed exactly right, must be on
Send [2nd][Link][SEND][G:SendOS]. (When both calculators hit [ENTER])
If
all that does not work, then it may be time to head for a place of
worship to pray for its resurection, or look for a repair shop.
Hope it helps
SOURCE: TI-83 Plus calculator: Only a line appears
Try the following steps before thinking of repairs.
Here are some steps to perform in the order they are presented.
I am inserting a copy of an earlier post to a question similar to
yours. Please read the post till the end.
A Try this before thinking of repairs.
B If that does not work
C. Third option
D. Last option
The last option requires the reinstallation of the system. So
to use it you must download the TIConnect 1.6 software from
education.ti.com. You must have the TI USB SilverLink or the TI Black serial cable ready.You must be connected to the Internet.
If the message "Error! Press any key to turn unit off. Then turn unit back on."
appears on the graphing calculator, quickly, remove one battery from the
calculator and reinstall it while the transfer is taking place.
You have several ways to connect the calculator
ive tried all the resets and none work
