My cursor used to be a single line that allowed me to enter characters anywhere but now it is a blinking square that moves from character to character. Does anyone know how to change that?
I had this same problem on my TI 89... You must have accidentally set your calculator to insert mode. To switch it back to the thin cursor, input the following keystrokes... Go to the "2nd" key to enter second function mode. Then press the button with an arrow on it pointing to the left(The key that you use to backspace). Do you see the "INS" lettering above the backspace key? There's your solution :-)
Thanks so much adriel867
Thanks man, my problem is solved now...Thanks X1 000 000 000 000
Please more detail on this problem, I couldn't resolve mine! Thanks :)
thanks, I found it too :) Used over a week to this ***, finally found your comment. Thanks alot :)
- 0, 1, 2, 3, 4, 5, 6, 7, 8, 9: Enter a character to the position pointed by the cursor.
- First press: enter the first character from a set of characters related to this button. Each subsequent press: you may change the entered character to the next one from this set.
- 0: enter the space.
- 1: enter a special character (punctuation marks, etc).
- Up, Down, Left, Right after pressing 1 (special character entering mode): select the required character.
- ENTER: confirm selection; finish text entering.
- SUBTITLE: enter the period (for numeric mode); functions like button 1 (character mode).
- CLEAR (<-): delete a character to the left of cursor.
- SELECT (cap'num): switch input mode:
- abc: character mode, small latin letters.
- ABC: character mode, capital latin letters.
- 123: numeric mode, digits.
- RETURN: cancel the text changes and finish text entering.
- Left/Right: move the cursor one character left/right.
- Up/Down: move the cursor to the start/end of a text line.
- If the cursor is already in start/end position: select another user interface element which is under/over the current text entry area (only for dialogs with several elements of user interface; text changes are confirmed automatically).
- POP UP MENU: show context menu with a list of available commands. They allow you to cut, copy and paste text using the clipboard, much like it is done on a PC.
- http://electronicshelponline.blogspot.com/
yeah man, same here
Thank you sooo much!!! that helped a ton
You have no idea how irritating this was! Thank you so much!
