SOURCE: Minolta 2300DL feed problem
I have the same problem. Which solenoid needs to be replaced, SL-5, SL-7, SL-9, SL-20 or SL-36 (info from pdf service manual).
SOURCE: Magicolor 2430 DL vertical white blank stripes
remove PC drum and under that you can see laser glass, clean it and reinstall.
SOURCE: A faded line prints across the page
The imaging bar has speck of dust on it.
Turn printer OFF.
Open the printer.
Pull out the transfer roller. Should have a big green handle. Do not touch the roller.
Look inside for a shiny rectangular block about 5inches x 0.5 inch.
This is the imaging bar. Using a lint free cloth with no chemical and no water, gently wipe this bar to remove any specks of dust/paper specks.
Put roller back.
Close the printer.
Turn printer ON.
Problem fixed.
SOURCE: Magicolor 2300dl horizontal paper folding
I kept digging until I found some helpful, lucky people that stumbled across a solution. The cost of doing the repair yourself is about $1 for superglue.
I detailed the repair in my blog: http://dlburkhart.spaces.live.com/blog/cns!5BA5F950B86A8BE5!182.entry.
I don't know if that URL will work as a permanent link. So, just in case, the same information is on my business web site on the Tech Tips page: http://www.BurkhartTech.com/Tips.html.
I hope to have helped.
If anyone can use a custom web site, I can really use the work. I left work a couple of years ago to be a stay-at-home dad and to try to start up a web site business. Things started out okay. But the economy soured, all of my business dried up, and now I can't find full time employment.
SOURCE: Magicolor 2300DL: prints low on first page, OK subsequent pages
I spoke to QMS about this since it happened to me. It is the registration roller in the transport unit going bad. Basically the clutch is slipping and they are seeing a lot of it on this model. The first page will slip because the clutch is sticking. , delaying the paper pickup . i also have the accordion problem which is where you are headed. this is where the clutch does not disengage when it is suppose to , causing the paper to fold.
The only solution to this is a new transport unit. It is the entire section in the back.. Looks like a bit of work to rip it out but straight forward.
Transport unit
8314131-0360-04
800-972-6705 - $87
I am going to call and order one next week, I’ll let you know how it works out.
