Guru
Runs but no heat? check your house breaker or fuses it takes 2 thirty amp breakers or fuses if you have breakers flip them off then back on several times. then try again still no heat you would need a volt- ohm meter to check the element, t-stats,thermal overloads etc. If you have fuses just replace them with 30 amp time delay fuses and try again.
