SOURCE: Need part number s for the entire head assembly of
Hello daniel_s_kmi:
If I Understand you, you are Looking for the Part Number for the Complete String Head.
If this is Correct, then the Part Number is DA3001A.
>>You can View a Breakdown of this Unit at this Site Addy; http://www.homelite.com/service_support and Select Order Parts. Now Select "Click to Launch Homelite Catalog". Now Enter the Model Numbers (UT-20721) and Click Search. Now Double Click on the Model in the Results Area. Now you can View the Breakdowns for this Unit. Select the "Shaft-Spool and String-Grass Deflector" File. The Complete String Head is # 17 in the Breakdown.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
SOURCE: Homelite Trimlite String Trimmer. String won't advance on tapping
remove assembly clean with soap and water and toothbrush(make sure when you dissasemble make notes of how to put back together!)Check spring make sure not broke or distorted-oil with silicon oil(walmart sells or auto parts store)reassemble reverse of dissassemble!!! hope this helps you!!!!
SOURCE: How to change the string
If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of
the line in the hole on the inside of spool.
Wind clockwise onto spool,
putting the line that is closest to the ground on first.
Once you have
winded this piece on, lock the last 4 inches of line through the slits
on spool.
Repeat process for second piece of line, locking the last 4
inches in slot opposite the other locked in piece.
Put the spool on the
trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the
locked position.
If it is a single line trimmer, just wind a single piece of string clockwise onto spool.
Jim
SOURCE: How do I remove the cutting head on my homelite HLT=15
http://www.ereplacementparts.com/homelite-hlt15-ut20602-string-trimmer-parts-c-18807_20299_21185.html
Here is a diagram of it. It is reverse threaded so you have to turn it like you was tightening it to loosen it. Clockwise looking at it from the bottom of the head. But there is a clutch that will let the whole thing turne. The best way is to remove the shaft from the weedeater and hold the shaft with some vice grips. Or you may be able to hold it right above the head, before the shaft tube.
