Tissot T Touch Navigator 3000 T96.1.488.42 watch Logo
Posted on Apr 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The digital time and the analog time are not synchronized
The wathc hav been working fine for almost a year, but suddently one morning, the minutes hand appears 15 minutes behind than the correct time. I check the digital time and it is correct. Also I noticed that when I choose any of the functions, the hour hand points correct, but the minutes hand is always 45 degrees behind. Any help? thanks
Arturs Kalnins
Level 3:
  • Master 2,338 Answers
  • Posted on Apr 04, 2009
Arturs Kalnins
Master
Level 3:
Answers
2338
Questions
9
Helped
1813053
Points
13579
Here is complete manual for your watch:
http://www.t-touch.com/t-touch_images/usersmanual/140-en.pdf
If you are not successful with this, maybe it's time to change the battery?
Read manual carefully and you will find out how to recognize: I'ts time to change the battery.
Rate me, please.
2answers
My Casio analogue display is showing 5 minutes slow whilst the digital display shows the correct time
If old model ana-digi watch you have to manually synchronize analog time with digital display.
13helpful
Have Rado 193. am trying to sync analog and digital time. Manual says turning crown slowly adjusts minutes. Does not - only hours change
You can adjust the analogue hands without changing the digital ONLY when you have set the watch to 24hr fornat. Do this by going to the second Timezone screen (T2) and pressing the crown once briefly. If A or P appears, the time display is in 12-hour mode. If no letter appears, the time display is in 24-hour mode. To change mode, press crown briefly a second time.
Now go to the basic display where no digital info is shown. Pull the crown out. Now slow turning will adjust the minutes and fast turning the hours, but only of the hands. Therefore you can synchronize the two. After they show the same time, press the crown back in and adjust both times together using the crown as normal on the standard "Time" digital screen
1helpful
Synchronize analog and digital time on Tissot T33 T-Touch Watch
I could not get any result from entering your model in their web site but the "T Touch online" seems to be a watch that has similar features perhaps.
Their catalogues seem to be generic, so by going to their web site http://support.tissot.ch/?mod_flashPDF/id_138 you may finswhat you need.
2answers
Analog hands lose time when worn.
This is usually a indication that the minute hand is slightly loose on its pinion. This requires that the hand be tightened, so that it does not slip. Best left to a watchmaker.
133helpful
4answers
Tissot t-touch analog time is out of sync with digital time. How do I res-sync them?
This is the tried and tested solution from this very nice gentleman. Many thanks to him (Ha Bi):
  1. Press and hold on to the T button until it beeps
  2. Touch the middle of the screen to change digital display to unit selection
  3. Press and hold the T-button until "Synchronize" comes up in the digital display
  4. Use the + button and - button to align the hour and minute hand to 12:00.
  5. Click on the T-button again. Congrats, you're done!
  6. Enjoy~
Must see blog for all T-touch users
http://myhabi.blogspot.com/2008/10/tissot-t-touch-battery-change.html
2answers
Problem Syncronizing the Analog & Digital
Hi ...
Oh yes, a problem which I also had :) easy to overlook this moment - even in the original instructions. Very accurate description of all the features of Citizen Ana Digi Temp - including how to set the time - and Synchronize Analog and Digital watch, you will find on
CITIZEN Ana Digi Temp
Best Regards
7helpful
2answers
Cant se time Citizen 8988-q02047 HSB wristwatch
In the time mode, press the upper right button for 2 seconds and the time display will flash. Then press the same button untill the entire time will flash, or both hour and minutes flash at same time. When the hour and minutes flash at same time, this adjust mode is the adjusting of the analog left display (A1). Now, press the lower button for adjusting de hour shown at the digital display that shows the same hour at analog display. This method is to adjusting the 8982 that is the "father" of 8988. Like a Citizen collector, and don´t know any website that you can view the setting instruction of 8988, only the 8982 is disposable here: http://www.citizenwatch.com/downloads/techguides/8982.pdf
1helpful
2answers
Digital/analog times not same/# of batteries
You need to synchronize the watch. You can find directions to do that online, but you will likely have to do this several times a year. There are so many functions that you will occasionally need to go to synchro mode to synch everything up. It freaked me out the first time I saw this too. : )
3helpful
7answers
Daylight Saving Time will not set correctly
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
Top Tissot Watches Experts
Ngoro
john h
k24674
Are you a Tissot Watch Expert? Answer questions, earn points and help others
