Fisher and Paykel GWL11 Top Load Washer Logo
Posted on Apr 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Rinse Cycle Doesn't Fill with Water
We just replaced the water pump on our GWL11 washer. Now it fills fine for the wash cycle, but just drips a very limited amount of water into the machine during the rinse cycle. Not nearly enough to rise the clothes.
During the wash cycle it gave the warning that either in inlet hose were disconnected, the water supply was off or there was a problem with drain hose. Checked and all were fine.
So maybe I need to replace the inlet valves?
When I put it in diagnostic mode, it said the obo switch was tripped. Would this cause the problem with no water during the rinse cycyle?
Anonymous
Level 2:
  • Expert 144 Answers
  • Posted on May 15, 2009
Anonymous
Expert
Level 2:
Answers
144
Questions
0
Helped
82967
Points
350
You may want to double check you have the inlet hoses around the correct way as if you have the cold hose going to the hot valve it would cause this fault. If the machine doesnt spin properly also it could be a faulty Out of balance switch. cheers.
Why won't my washer fill up with water on the rinse cycle?
something hindering the rinse cycle? bad water pump or clogged pump?
1helpful
Kenmore Model 21082000 won't fill during wash cycle
Try checking the lid switch. Sometimes the switch goes bad or the stem breakes and when the lid shuts it will not activate the switch. Usually located on the right side of the dryer. When the lid closes it will allow water to.fill. Washers are easy to fix and the part is cheap. Get it from amazon dont pay the crazy price your dealer wants. Trust me, i just fixed my mothers...
Washer is getting stuck at rinse cycle-
sorry to keep asking questions but i just need to know a little more information. are you using auto fill? have you tried manual water level settings? is your machine the one with the LCD DISPLAY?when it stops at rinse, is it agitating? if you have the LCD display have you tried the- traditional wash mode? please reply 4 further help.
1helpful
Fills to wash, drains but then tub won't fill for rinse cycle;
u need a new cold water valve, if u check the temp of the water while its filling it is mainly hot, or u have the hot nd cold hoses on the wrong way , as all rinses r cold
3helpful
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
5helpful
2answers
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Washer only fills with hot water
Probably a bad water inlet valve. To verify, you would have to check continuity at the valve.
http://tclaundryrepair.com/home
2answers
Cold water will not stop filling during rinse
while the unit is filling in the warm cycle. reach behind and shut off the hot water tap.I bet the water flow stops filling, if so, you would need to change the inlet valve on the machine. You see, in warm, if the cold is not filling, you still hear the hot filling and the unit will advance. The rinse cycles are mostly "cold" only. if the valve is not opening it will not allow it to advance from the rinse section on the board.
Top Fisher and Paykel Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
