Disney Pix Click Digital Camera Logo
Anonymous Posted on Aug 04, 2013
How to connect pc - Disney Pix Click Digital Camera
How do I change source resolution on my TV?
connecting PC to Tv through VGA - Tom's Guide
www.tomsguide.com/answers/id-1891563/connecting-vga.html
Nov 20, 2013 - Q: Can I connect the TV to the PC via a VGA cable...bearing in mind the .... Forum; SolvedI'm trying to connect my Sony bluray player home ...
Connecting my Plasma to my PC via the VGA port. - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - Ensure that the VGA cable is working properly using other methods. Perhaps .... I am trying to connect my pc with my samsung tv. .... I'm very sorry to hear that has happened, and I apologize for any inconvenience this may have caused you. Connection between Dell laptop and Samsung TV
Jun 11, 2015
How to connect computer to tv with sound and picture?
Jun 5, 2015
PC Audio won't play through connected Samsung LCD TV
Jun 4, 2015
Connecting computer to TV
Jan 18, 2008
More results from www.cnet.com
My custom built PC will not connect to my TV via VGA cable ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Jun 28, 2013 - 5 posts - ‎2 authors
1helpful
How to connect Hitachi camcoder with laptop
Connecting to PC via PC Connection Cable
Use the provided PC connection cable to connect the DVD video camera/recorder to PC as shown in the last.
Note:
• No data can be written to the HDD, disc or SD memory card in this DVD video camera/recorder when it is connected to PC.
• The PC connection cable does not supply power to the DVD video camera/recorder: Use the AC adapter/charger
to power the DVD video camera/recorder.
• Before connecting the DVD video camera/recorder to PC, disconnect any cables or camera accessories (external
video flash, external microphone, etc.) other than the PC connection cable and AC adapter/charger.
• When connecting the DVD video camera/recorder to PC, the ACCESS/PC indicator will light green. While HDD or
a disc is being accessed, the indicator will light or blink orange. While an SD memory card is being accessed, the
CARD ACCESS indicator will light or blink red.
If you connect the DVD video camera/recorder to PC via PC connection cable, the PC will automatically recognise the DVD video camera/recorder. After recognition is finished, it may be
prompted to restart the PC: In this case, follow the instruction and restart the PC.
2helpful
How can i install nokia pc suit in nokia 3110c right now
hOw?
You need pc with suitable pc suite nokia for your phone.
Then you need Bluetooth or cable to connect between your pc and your phone.
If you have this then you open pc suite nokia on your pc.
Link PDF GUIDE PC SUITE
lInk to download pc suite 7
that new version pc suite.
After you have installed the pc suite to your pc, then connect, it will ask you to install at phone.
IF YOU HAVE BLUETOOTH DEVICE AT YOUR PC/LAPTOP, THEN YOU CAN CONNECT IT . TRY CONNECT IT FIRST USING BLUETOOTH. THEN IF IT WAS CONNECTED, USING PC SUITE.
1helpful
2answers
My phone is not unable to connect in my pc if i connect in my pc no new hardwre is not found
Go to your phone settings and adjust the pc connections.If it has been set to mass storage,then connect your phone via usb, and if it has been set to pc suite , then install the pc suite and connect it to your PC.
Mar 23, 2011 • Cell Phones
How to connect bsnl 3G to pc using samsung...
HI YOU CAN CONNECT THE BSNL 3G WITH SAMSUNG MOBILE BEFORE DOING SO YOU NEED TO INSTALL THE SAMSUNG PC SUIT IN YOUR PC AND AFTER THAT YOU NEED TO CONNECT YOUR MOBILE TO PC USING DATA CABLE ONCE PC SUIT IS OPENED AND DATA CABLE IS CONNECTED
IN PC SUIT SELECT THE CONNECT BUTTON AND FOLLOW STEPS
NOW YOU BSNL 3G WILL BE CONNECTED TO INTERNET.
THANK YOU
3helpful
I bought samsung s3310 but my mobile is not connecting with pc. My Email [email protected]
pc setting in pc suit .
just open pc suit , u will get a option of manage ur connection ,click on that , u will get a option of new connection , click on that ,then the enetr the connection name , ( in idea connection - idea ), then select country from drop list (india ), then APN (access point name like in idea connection "apn is internet"),,aftrer that , there is no need to fill any option ,and click on finish , after click on connect, after that ur pc will connect with web.,
download the PC suit here-->http://www.giveawayoftheday.com/pc+studio+1.1.2+id3/
Thanks for rating good luck
Jan 27, 2011 • Cell Phones
Sir i need procedure for connecting with pc sir..please help me sir
To connect your phone with a PC, there are several ways, but i will explain two ways in which you can connect your PC.
1. Via Bluetooth: You can connect your PC via bluetooth by turning ON your bluetooth from your PC and your phone to establish a connection. Search for your PC from your phone.
2. Via USB cable: You can connect your phone to your PC via USB cable. You will connect your USB cable from your phone and insert it into a USB slot to be able to copy files to your system.
Best regards
PC will not connect unless Laptop is turned on?
first reset the connection, and try to connect the pc with switch and when net start working the connect the laptop
Hi sir i have a problem that  how to share the individual internet connection on other pcs
To share the induvidual internet connection with other pc s you need the following:
1. The pc which owns the internet it need an ethernet connection too.
2. The other pc's which dont have internet connection it needs
3. You need an equipment which connects the internet pc and
other pcs. It called Ethernet switch.
Linksys company has a good product, which can connect 4 pc together, called linksys Wrtg54gl. It not only a small switch
it also has the capability to connect wifi devices.
Buy this router connect the pc-s to thos router with ethernet switch. You need to set up ip addresses for the pc-s.
The whole procedure is well written in the Linksys admin manual.
I hope it helps.
Here is the router manual:
ftp://ftp.linksys.com/pdf/wrt54g_ug.pdf
If you dont need the wifi router (you dont need wireless connection buy this model:
Linksys BEFSR41
If you need to connect more than 4 pc it requires a new solution.
If all pc are connected with ethernet together, you need another solution.
If you has a problem with this write to the forum, i will respond you.
Have connected the wireless router,I am receiving internet to laptop but now internet is lost from pc. Connection has been installed correctly i think.
you should make a connection from your PC to your router then connect your laptop to your PC's internet connection... you will need 2 dongles 1 in your PC and 1 in your laptop (unless you have it built in). get the connection on the PC first then find the connection from your laptop to your PC
Top Disney Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Tony Parsons
Tony Parsons
Are you a Disney Camera Expert? Answer questions, earn points and help others
